ASUS Q400A-BHI7N03 Power Jack Replacement
Выберете то, что вам нужно
  1. ASUS Q400A-BHI7N03 Power Jack Replacement, Power Jack: шаг 1, изображение 1 из 1
    • Flip laptop over with the battery facing toward you.
    • Slide both tabs with the lock/unlock symbol, near the battery on the right of the notebook, to the unlock position.
    • Grab the top edge of the battery & lift upward to relieve the battery from its slot.
  2. ASUS Q400A-BHI7N03 Power Jack Replacement: шаг 2, изображение 1 из 1
    • Remove the one black 8mm Phillips #0 screw.
    • Lift and remove the bottom cover panel using the plastic opening tool.
  3. ASUS Q400A-BHI7N03 Power Jack Replacement: шаг 3, изображение 1 из 1
    • Remove the four 8mm Phillips #0 screws.
    • Lift and remove the drive.
  4. ASUS Q400A-BHI7N03 Power Jack Replacement: шаг 4, изображение 1 из 1
    • Remove the single silver 8mm Phillips #0 screw.
    • Remove the three 8mm Phillips #0 screws.
  5. ASUS Q400A-BHI7N03 Power Jack Replacement: шаг 5, изображение 1 из 1
    • Remove the seven black 8mm Phillips #0 screws around the perimeter.
    • Remove the two silver 8mm Phillips #0 screws that are under the battery.
  6. ASUS Q400A-BHI7N03 Power Jack Replacement: шаг 6, изображение 1 из 1
    • Flip the device right-side up and pry up the keyboard and touchpad gently using both hands.
  7. ASUS Q400A-BHI7N03 Power Jack Replacement: шаг 7, изображение 1 из 1
    • Release the ZIF (zero insertion force) connector using a plastic spudger.
    • Remove the ribbon cable by hand from the ZIF connector.
    • Do not use too much force when releasing the ZIF connector.
  8. ASUS Q400A-BHI7N03 Power Jack Replacement: шаг 8, изображение 1 из 2 ASUS Q400A-BHI7N03 Power Jack Replacement: шаг 8, изображение 2 из 2
    • Remove the two remaining ribbon cables as described in Step 7.
  9. ASUS Q400A-BHI7N03 Power Jack Replacement: шаг 9, изображение 1 из 1
    • Unscrew the two black 8mm Phillips #0 screws.
    • Firmly grasp each antenna head with a pair of blunt tweezers and detach it by lifting up straight.
    • The antenna cables are connected through small sockets. Small popping sounds when attaching and detaching the antennas are normal.
  10. ASUS Q400A-BHI7N03 Power Jack Replacement: шаг 10, изображение 1 из 1
    • Remove the five black 8mm Phillips #0 screws.
  11. ASUS Q400A-BHI7N03 Power Jack Replacement: шаг 11, изображение 1 из 1
    • Firmly grab the optical drive and remove it by sliding it out.
  12. ASUS Q400A-BHI7N03 Power Jack Replacement: шаг 12, изображение 1 из 2 ASUS Q400A-BHI7N03 Power Jack Replacement: шаг 12, изображение 2 из 2
    • Lift the motherboard gently to completely remove this component from the device.
    • Detach Audio Cable gently by hand and you have now access to replace the power jack.
Заключение
Еще один человек закончил это руководство.
Wan Ahmad Aiman
Участник с: 10/31/18
403 Репутация
Автор 2 руководств
Команда
IUPUI, Team S1-G3, Harley Fall 2018 Участник IUPUI, Team S1-G3, Harley Fall 2018
IUPUI-HARLEY-F18S1G3
3 членов
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 844
