Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If the screen is damaged, or has an incorrect display, it should replaced. The following is a comprehensive guide for replacing the screen.
Выберете то, что вам нужно
Flip the laptop on its back side with the battery facing toward you.
Slide the tabs with lock/unlock symbol, to the unlock position.
Grabbing the top edge of the battery, lift upward to relieve the battery from its slot.
Lift the two black plastic circles off the screen using the plastic spudger.
Unscrew the two 8mm Phillips #0 screws.
3 участников успешно повторили данное руководство.
Один комментарий
Can you tell me what is the part number and description for the display, I need to order one to replace mi ASUS broken screen. Thanks in advance...!!!
