Выберете то, что вам нужно
Remove ten 2 mm screws using a Phillips #0 screwdriver.
Remove the screw in the center using a T4 Torx screwdriver.
Use an iFixit opening tool to pry open the back panel.
Remove the six 2 mm screws from the hinges using a Phillips #0 screwdriver.
Using your fingers, unplug the two power cables connecting the display to the motherboard.
Remove the display assembly from the laptop.
