Введение
Before proceeding with an SSD upgrade or replacement in a laptop, it's crucial to check compatibility with the laptop model, ensure proper backup of important data, and consider factors such as budget and specific performance requirements.
Выберете то, что вам нужно
Remove ten 2 mm screws using a Phillips #0 screwdriver.
Remove the screw in the center using a T4 Torx screwdriver.
Use an iFixit opening tool to pry open the back panel.
To reassemble your device, Follow these instructions in reverse order.
