ASUS ROG G75VX-BHI7N11 Fans Replacement
Выберете то, что вам нужно
  1. ASUS ROG G75VX-BHI7N11 Fans Replacement, ASUS ROG G75VX-BHI7N11 Disassembly: шаг 1, изображение 1 из 1
    • Remove the 6 screws on the edge of the laptop using a screwdriver.
    • Remove the back casing being held on by the one single screw. First, lift the casing at the edge where the screw once was, then carefully lift at the rest of the edges to loosen the casing. Pull the casing towards the edge where the screw was.
    • Remove the battery by sliding the switch circled in the picture and pulling the battery out.
  2. ASUS ROG G75VX-BHI7N11 Fans Replacement: шаг 2, изображение 1 из 1
    • Remove the 11 screws circled in the picture using a Phillips head screwdriver. They should be labeled on the laptop with a capital A, shown circled in red.
    • Remove the screw labeled C.
  3. ASUS ROG G75VX-BHI7N11 Fans Replacement: шаг 3, изображение 1 из 1
    • Remove the 5 screws circled in the picture, located where the battery pack once was.
  4. ASUS ROG G75VX-BHI7N11 Fans Replacement: шаг 4, изображение 1 из 1
    • Remove the DVD ROM on the side of the computer, by pulling it out. If necessary, use a plastic opening tool.
  5. ASUS ROG G75VX-BHI7N11 Fans Replacement: шаг 5, изображение 1 из 1
    • Remove the three screws located where the DVD ROM once was, on the screen side of the laptop.
  6. ASUS ROG G75VX-BHI7N11 Fans Replacement: шаг 6, изображение 1 из 3 ASUS ROG G75VX-BHI7N11 Fans Replacement: шаг 6, изображение 2 из 3 ASUS ROG G75VX-BHI7N11 Fans Replacement: шаг 6, изображение 3 из 3
    • Flip the laptop over and pop the back cover off behind the screen, by grabbing it on either side and pulling it up, vertically off of the laptop.
    • There is a cable connecting the cover to the laptop, shown in picture 2.
    • Disconnect the cable by pulling apart the white connectors, shown in picture 3.
  7. ASUS ROG G75VX-BHI7N11 Fans Replacement: шаг 7, изображение 1 из 2 ASUS ROG G75VX-BHI7N11 Fans Replacement: шаг 7, изображение 2 из 2
    • There will be two smaller and two larger black screws on each hinge holding the laptop screen onto the computer. Remove all four of the larger screws with your P0 screwdriver.
    • There is one screw on either side of the keyboards, next to the screen hinges. Remove both screws.
  8. ASUS ROG G75VX-BHI7N11 Fans Replacement: шаг 8, изображение 1 из 2 ASUS ROG G75VX-BHI7N11 Fans Replacement: шаг 8, изображение 2 из 2
    • You may now remove the keyboard plate. Simply lift from the back, and pull it off all the way around.
    • Caution with removing the keyboard, as there are 5 ribbon cables that connect the motherboard to the keyboard (motherboard port locations shown in picture 2).
    • The ribbon cables must be carefully disconnected from the motherboard side, by flipping a latch on the port and pulling the ribbon out.
  9. ASUS ROG G75VX-BHI7N11 Fans Replacement, Fans: шаг 9, изображение 1 из 2 ASUS ROG G75VX-BHI7N11 Fans Replacement, Fans: шаг 9, изображение 2 из 2
    • Remove the three black screws holding the fan in place.
    • Remove the multicolored wires by simply pulling outward, away from you, and sliding it out of its port.
  10. ASUS ROG G75VX-BHI7N11 Fans Replacement: шаг 10, изображение 1 из 1
    • Remove the second fan by unscrewing the three black screws circled in the picture in red.
    • Detach the multicolored cables by pulling the connector out of its port, to your left.
  11. ASUS ROG G75VX-BHI7N11 Fans Replacement: шаг 11, изображение 1 из 1
    • Carefully slide the fans upwards and outwards towards you (here shown as the bottom of the picture)
    • Note that there is tape holding the fan to the heatsink
Заключение
5 участников успешно повторили данное руководство.
Logan Smith
Участник с: 01/25/17
783 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 8-3, Banghart Winter 2017 Участник Cal Poly, Team 8-3, Banghart Winter 2017
CPSU-BANGHART-W17S8G3
4 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 2,015
