Введение
In this guide, we will show you how to remove the back casing for the ASUS Transformer Book Flip TP500LA. It is necessary to remove the back case in order to access the computer's battery, fan, and all components on its motherboard.
Выберете то, что вам нужно
Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
Slide a heavy-duty spudger between the back case and the computer.
Slowly work around the edges to undo the clips to fully separate the back case from the computer.
Gently lift off the back case.
Еще один человек закончил это руководство.
