Введение
In this guide, we will show you how to remove the back casing for the ASUS Transformer Book Flip TP500LA. It is necessary to remove the back case in order to access the computer's battery, fan, and all components on its motherboard.
Запчасти
No parts specified.
  1. Remove the ten 10 mm Phillips #0 screws found on the computer's back case. Remove the ten 10 mm Phillips #0 screws found on the computer's back case. Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
    • Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
  2. Apple Watch Kits
    Screen and battery repairs just got easier.
    Купить сейчас
    Apple Watch Kits
    Купить сейчас
  3. Slide a heavy-duty spudger between the back case and the computer. Slowly work around the edges to undo the clips to fully separate the back case from the computer.
    • Slide a heavy-duty spudger between the back case and the computer.
    • Slowly work around the edges to undo the clips to fully separate the back case from the computer.
    • Gently lift off the back case.
Заключение
Garrett Fitzpatrick
Участник с: 10.04.2017
641 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S13-G5, Forte Spring 2017 Member of Cal Poly, Team S13-G5, Forte Spring 2017
CPSU-FORTE-S17S13G5
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 32
