Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
Slide a heavy-duty spudger between the back case and the computer.
Slowly work around the edges to undo the clips to fully separate the back case from the computer.
Gently lift off the back case.
Slide a heavy-duty spudger into the ZIF connector and gently flip up the retaining flap to open the connector.
Pull the blue tab to remove the ribbon.
Remove the three 5 mm Phillips #0 screws.
Remove the single 6 mm Phillips #0 screw.
Use the heavy-duty spudger to pry the white 8-pin connector away from the motherboard.
Gently pull the connector away from the motherboard.
Use the blue plastic opening tool to loosen and remove the three black wires from the battery.
Slide the battery out from the computer to remove.
14 участников успешно повторили данное руководство.
