Введение
This guide will inform you on how to replace your hard drive. This replacement will be very easy as there are only a few screws that need to be taken out during this guide to access and remove the hard drive.
Выберете то, что вам нужно
Turn the laptop over to the back.
Unscrew the two 3mm Phillips screws using a PH0 screwdriver.
Lift the small black panel upward by putting your fingernail in the provided slot.
Use the J1 screwdriver to unscrew the four 3mm Phillips screws on the hard drive.
