Введение
If your laptop makes a buzzing sound or seems to be overheating, the fan might need to be cleaned or replaced. This guide will help you remove the fan to clean or replace it.
Выберете то, что вам нужно
Remove the two 2 mm Phillips head screws on each side on the bottom using PH00 screw driver.
Remove the one 2 mm screw underneath the black cover in the middle using the same screw driver.
Remove the three 2 mm Phillips head screws on the hard drive using PH00 screw driver.
Remove the remaining seven 1.8 mm Phillips head screws using the same screw driver.
Remove the six 2 mm Phillips head screws on the top edge of the laptop using PH00 screw driver.
Flip the laptop right-side up and open the screen.
Starting in a corner of the keyboard, pry the keyboard from the laptop using a plastic opening tool.
Remove the ribbon cable on the bottom of the keyboard by lifting up on the tape and pulling up.
Remove the four 2 mm Phillips head screws from the top of the motherboard and fan using PH #1 screwdriver.
Remove the blue cable on the bottom right by lifting up on the tab and pulling the cable out.
Peel off the black and yellow tape attaching the fan to the base.
Peel the tape off the yellow cable and pull out to remove the cable.
Remove the small black, white and red cable next to the yellow cable at the top.
Carefully and slowly lift up the motherboard from the base and remove the red and black cable underneath the motherboard in the top left corner near the fan.
Remove the four 2 mm Phillips head screws surrounding the copper rod using PH1 screw driver.
Remove the red, blue, black and yellow cable attaching the fan and motherboard together with your fingers.
Now the motherboard and fan are completely separate from each other.
