Введение
If you are experiencing problems with your fan or motherboard, this guide will help you to remove the front panel assembly to replace it or reach other components underneath the keyboard.
Выберете то, что вам нужно
Remove the two 2 mm Phillips head screws on each side on the bottom using PH00 screw driver.
Remove the one 2 mm screw underneath the black cover in the middle using the same screw driver.
Remove the three 2 mm Phillips head screws on the hard drive using PH00 screw driver.
Remove the remaining seven 1.8 mm Phillips head screws using the same screw driver.
Remove the six 2 mm Phillips head screws on the top edge of the laptop using PH00 screw driver.
Flip the laptop right-side up and open the screen.
Starting in a corner of the keyboard, pry the keyboard from the laptop using a plastic opening tool.
Remove the ribbon cable on the bottom of the keyboard by lifting up on the tape and pulling up.
