Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Open the laptop until it is flat and lay it screen down.
Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
Remove two 4.8mm Phillips from the corners of the device.
Turn the device face up.
Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
Remove the keyboard panel completely.
Remove the white ribbon cable shown by pulling on the blue tab.
Remove the black cable found beneath the white ribbon cable that you just removed.
Disconnect the battery from the motherboard by unplugging the wire bundle shown.
Unscrew the 3/16 inch long screw that holds the battery to the chassis using a #00 Phillips Screwdriver.
Lift the battery from the chassis.
