ASUS VivoBook Flip TP501U CPU Fan Replacement
Выберете то, что вам нужно
  1. ASUS VivoBook Flip TP501U CPU Fan Replacement, Keyboard Panel: шаг 1, изображение 1 из 2 ASUS VivoBook Flip TP501U CPU Fan Replacement, Keyboard Panel: шаг 1, изображение 2 из 2
    • Open the laptop until it is flat and lay it screen down.
    • Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
    • Remove two 4.8mm Phillips from the corners of the device.
  2. ASUS VivoBook Flip TP501U CPU Fan Replacement: шаг 2, изображение 1 из 1
    • Turn the device face up.
    • Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
    • Pull the panel away from the chassis CAREFULLY, as there are ribbon cables attached between the keyboard and internal electronics.
  3. ASUS VivoBook Flip TP501U CPU Fan Replacement: шаг 3, изображение 1 из 1
    • With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
    • Remove the keyboard panel completely.
  4. ASUS VivoBook Flip TP501U CPU Fan Replacement, WiFi Card: шаг 4, изображение 1 из 3 ASUS VivoBook Flip TP501U CPU Fan Replacement, WiFi Card: шаг 4, изображение 2 из 3 ASUS VivoBook Flip TP501U CPU Fan Replacement, WiFi Card: шаг 4, изображение 3 из 3
    • Locate and remove the single 3.17 mm screw holding in the WiFi card suing a Phillips #00 driver.
    • Disconnect the card from the motherboard by pulling down on the card.
    • Unplug the two black and white wires from the bottom of the card. They should pop off.
  5. ASUS VivoBook Flip TP501U CPU Fan Replacement, CPU Fan: шаг 5, изображение 1 из 2 ASUS VivoBook Flip TP501U CPU Fan Replacement, CPU Fan: шаг 5, изображение 2 из 2
    • Unscrew the five 4.8mm Phillips #00 screws holding in the hard drive mounting bracket.
    • Slide the mounting bracket towards the battery to disconnect the hard drive from the motherboard.
  6. ASUS VivoBook Flip TP501U CPU Fan Replacement: шаг 6, изображение 1 из 3 ASUS VivoBook Flip TP501U CPU Fan Replacement: шаг 6, изображение 2 из 3 ASUS VivoBook Flip TP501U CPU Fan Replacement: шаг 6, изображение 3 из 3
    • Detach the white ribbon cable.
    • Detach the black ribbon cable.
    • Disconnect the battery from the motherboard.
    • Disconnect the motherboard power cable.
  7. ASUS VivoBook Flip TP501U CPU Fan Replacement: шаг 7, изображение 1 из 2 ASUS VivoBook Flip TP501U CPU Fan Replacement: шаг 7, изображение 2 из 2
    • Remove the ten 4.8mm Phillips #00 screws.
    • There will be one more wire still attaching the motherboard to the chassis. Do not disconnect it, but just remove the motherboard from the case.
  8. ASUS VivoBook Flip TP501U CPU Fan Replacement: шаг 8, изображение 1 из 1
    • Flip over the motherboard to see the underside.
    • Remove the 9.5mm screw using the Phillips #00 screwdriver.
    • Remove the four 3.2mm screws using the Phillips #00 screwdriver.
  9. ASUS VivoBook Flip TP501U CPU Fan Replacement: шаг 9, изображение 1 из 2 ASUS VivoBook Flip TP501U CPU Fan Replacement: шаг 9, изображение 2 из 2
    • Disconnect the fan wire.
    • Remove the fan from the device.
Заключение
3 участников успешно повторили данное руководство.
Trevor Hack
Участник с: 01/14/20
197 Репутация
1 руководство автора
Команда
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 7
За всё время: 859
