Введение
If your laptop is unable to turn on without being plugged into an outlet, it may be suffering from a dead battery. In this guide we will be replacing the battery of the ASUS VivoBook S300CA-BBI5T01 laptop.
Инструменты
Запчасти
Детали не указаны.
Place the laptop upside down so that the bottom panel is facing upwards.
Unscrew the following 10 screws
Eight 5 mm Phillips head screws
Two 10 mm Phillips head screws
Remove the 7 screws holding the battery in place.
Six 3 mm Phillips head screws
One 5 mm Phillips head screw
Disconnect the one flat topped wire connector by carefully using a plastic opening tool to pry up both sides and then lifting the connector from its socket.
Еще один человек закончил это руководство.
