Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
If your laptop is unable to turn on without being plugged into an outlet, it may be suffering from a dead battery. In this guide we will be replacing the battery of the ASUS VivoBook S300CA-BBI5T01 laptop.
Запчасти
Детали не указаны.
  1. Place the laptop upside down so that the bottom panel is facing upwards.
    • Place the laptop upside down so that the bottom panel is facing upwards.
  2. Unscrew the following 10 screws
    • Unscrew the following 10 screws
    • Eight 5 mm Phillips head screws
    • Two 10 mm Phillips head screws
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Carefully peel the panel off of the bottom of the laptop.
    • Carefully peel the panel off of the bottom of the laptop.
  5. Remove the 7 screws holding the battery in place.
    • Remove the 7 screws holding the battery in place.
    • Six 3 mm Phillips head screws
    • One 5 mm Phillips head screw
  6. Disconnect the one flat topped wire connector by carefully using a plastic opening tool to pry up both sides and then lifting the connector from its socket.
    • Disconnect the one flat topped wire connector by carefully using a plastic opening tool to pry up both sides and then lifting the connector from its socket.
  7. Slide out the battery.
    • Slide out the battery.
Заключение
Еще один человек закончил это руководство.
Keith Rachels
Участник с: 04.03.2016
595 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team 3-4, Bhusal Spring 2016 Участник UMass Dartmouth, Team 3-4, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G4
2 членов
Автор 5 руководств
Один комментарий
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 9
За последние 30 дней: 24
За всё время: 3,083
