Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This guide's focus is on replacing the Wi-Fi card of a wireless desktop computer. Please follow the directions below to accomplish this result.
Запчасти
Детали не указаны.
  1. Place the laptop upside down so that the bottom panel is facing upwards.
    • Place the laptop upside down so that the bottom panel is facing upwards.
  2. Unscrew the following 10 screws
    • Unscrew the following 10 screws
    • Eight 5 mm Phillips head screws
    • Two 10 mm Phillips head screws
  3. Наборы переключателей Nintendo
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Carefully peel the panel off of the bottom of the laptop.
    • Carefully peel the panel off of the bottom of the laptop.
  5. Remove the one 3 mm Phillips head screw holding the Wi-Fi card in place.
    • Remove the one 3 mm Phillips head screw holding the Wi-Fi card in place.
  6. Carefully slide the card out of its connection port by pulling it outward.
    • Carefully slide the card out of its connection port by pulling it outward.
  7. Remove the black and white antenna cable connector wires by carefully pulling upwards on them.
    • Remove the black and white antenna cable connector wires by carefully pulling upwards on them.
    • Note that the black wire connects to "Main" and the white wire connects to "Aux".
Заключение
Keith Rachels
Участник с: 04.03.2016
595 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team 3-4, Bhusal Spring 2016 Участник UMass Dartmouth, Team 3-4, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G4
2 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 374
