Введение
The I/O daughter board holds two USB 2.0 ports, the combination headphone/microphone jack, and an SD card slot.
Выберете то, что вам нужно
Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
Use a spudger or your fingers to go around and lift the edges and release the back panel.
Using a spudger, lift up the plug connecting the battery to the motherboard.
Remove the two screws securing the left hinge to the I/O board.
Pry the hinge up by hand to a 90 degree angle.
Lift the board on the ribbon cable side far enough to clear the guide pin(s) then pull it back away from the side of the case.
