Введение
Random access memory aka RAM, is used for a short-term storage for your laptop. Memory size can vary for personal needs. This step will help you if you need to replace your RAM or if you want to increase your RAM size in your ASUS Vivobook Q301LA-BSI5T17 laptop.
Выберете то, что вам нужно
Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
Lift the perforated metal cover up from the motherboard to expose the memory cards.
Once the cover is removed the RAM will be accessible.
Use your fingertips to pry out the metal guards outlining both of the sides of the memory card.
Using your fingertips, slide the memory card out from the plastic housing and remove it from the board.
