Введение
The motherboard is a somewhat complex piece to take apart but only because there are so many things which are connected to it. In order to replace the motherboard you must disconnect the the Hard drive, LED lights, IO board, battery, fan and the wifi card. All of these are already in guides and are considered prerequisites for the motherboard replacement which is just a matter of taking out five screws and carefully pulling out the motherboard.
Выберете то, что вам нужно
Use the Phillips #00 screwdriver to remove the seven 90mm screws.
Use the Phillips #00 screwdriver to remove the four 50mm screws.
Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
Remove the four 5mm screws that attach the hard drive bracket using the Phillips #0 screwdriver.
Use the plastic opening tool to flip up the small clamp and pull out the ribbon cable.
Use 1 or 2 plastic opening tools to push down the small black plastic clips.
Pull the board up and out.
Locate the I/O board on the left of the computer. Using the Phillips #0 screwdriver, unscrew the three 5mm screws to unhinge the screen, which will free the board allowing it to be removed and replaced.
Unplug the power strip connecting to the motherboard with your fingers or plastic opening tool.
Unplug the battery from the laptop in the upper right hand corner of the battery using tweezers.
Use the Phillips #00 Screwdriver to carefully remove the 6 screws holding the battery in place.
Once you have removed all six screws carefully lift the battery out and dispose.
Use the Phillips #0 screwdriver to remove the last five 5mm screws holding the motherboard down.
Use the plastic opening tool to unclip the two wires from the Wi-Fi card that are connected to the motherboard.
Flip the motherboard over and use the plastic opening tool to unplug the black and red wires from the motherboard.
Еще один человек закончил это руководство.
