Введение
This guide will show you how to replace the screen on a ASUS X552LAV-BBI5N08 laptop.
Выберете то, что вам нужно
Slide the right button to the left.
Hold the left button to the right.
While you hold the left button in position, slide the battery out by pushing it away from you.
Remove the six 12mm screws located at both the battery area and the bottom panel, with a Tri-wing Y1 screwdriver.
Slide the bottom panel down and lift it up to remove.
Remove the seven 5.5mm screws located at the bottom area with a Tri-wing Y1 screwdriver.
Use an opening tool to split keyboard from base of the laptop.
Make sure to start from one end and go around the edges.
Flip laptop to sit on its bottom.
Lift keyboard up by the front edge.
Flip up the small locking flap for the two ZIF connectors.
Unplug the connectors that are keeping the keyboard connected.
Flip laptop to sit with the screen on the bottom.
Use tweezers to remove the square decorative sticker from the top of screws from the edge of the screen frame.
Remove six 4mm screws (with a JIS #1 screwdriver) from under the stickers and both of the hinges.
Use an opening tool to pry apart the frame from the edge of the screen
Go around the edges til the frame pops off from the screen
Remove eight 4mm screws from the corners of the screen using a JIS #000 screwdriver.
Flip the screen towards the bottom panel face down.
Use tweezers to remove the tape from the top of yellow lock.
Open the yellow ZIF connector.
Remove the casing from the edges of the screen by removing the eight 2mm screws with a JIS #000 screwdriver.
Pull the screen up to remove it.
