Введение
This guide will demonstrate how to replace the back camera of a Zenfone 3. This may be necessary if the camera no longer shows a picture or shows a distorted picture. For this guide, you will need the tweezers, Torx T2 screwdriver, a prying tool, and the Phillips #00 screwdriver.
Выберете то, что вам нужно
Using a pair of tweezers, pull put the SIM card tray and set it to the side.
Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
Remove the 3 mm screws, using the Phillips #00 screwdriver, from the black plastic piece at the top on the right side.
Remove the 3 mm screws, using the Phillips #00 screwdriver, from the metal piece around the camera.
Один комментарий
Excellent article. Just one question; who is selling this camera?
