Введение
This guide will demonstrate how to replace the fingerprint scanner of a Zenfone 3. This may be necessary if the scanner no longer activates or inaccurately reads fingerprints. For this guide, you will need the tweezers, Torx T2 screwdriver, a prying tool, and the Phillips #00 screwdriver.
Выберете то, что вам нужно
Using a pair of tweezers, pull put the SIM card tray and set it to the side.
Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
Unplug the wire connecting the two large pieces of the device. Next, seperate the two halves of the phone.
