Введение
A step-by-step guide to removing and installing a vibration motor
Выберете то, что вам нужно
On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
Use the T5 Torx driver to remove the four screws on the case.
The case will pry easily off with just gentle hand pressure
Using the tweezers, gently remove the fabric protecting the battery connection.
Use the heavy duty spudger to gently push the contact towards the top of the case.
With the metal tweezers gently remove the fabric covering the connection on bottom right
Using the heavy duty plastic spudger pry up on the connection ribbon.
The protective plate is now ready to be safely removed.
With the heavy duty spudger pry up on the metal plate, in a counter-clockwise pattern
Remove loosened plate and set aside.
With heavy duty spudger lift up on final connection ribbon located on left corner.
With all the connections disconnected the motherboard can be gently pried up and out of the watch case.
With a flat metal spudger pry back the little metal clamps that hold the motor secure.
With the soldering iron, heat the two solder tabs on back of motor.
Use metal tweezers to pull up and remove motor.
Еще один человек закончил это руководство.
