Введение
Use this keypad replacement guide if buttons are missing or damaged. A potential hazard would be affecting the motherboard through the charge that you internally carry, therefore you should use the anti-static wrist strap to prevent this. References to the other guides will be used.
Выберете то, что вам нужно
Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
Unplug the battery by squeezing your hands on the small white plug and lifting it up.
The battery is now detached and ready to be removed by lifting it out.
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
