Введение
This guide will show you how to replace the keypad from the phone. You may need to replace it if the keypad doesn't work when attempting to dial.
Выберете то, что вам нужно
Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
Pull up on the spudger while simultaneously pulling up the top shell of the phone.
After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
3 участников успешно повторили данное руководство.
