Выберете то, что вам нужно
Loosen the back cover using the suction cup.
Pull up on all four corners of the back with the suction cup.
Gently place the small opening tool in the crevice created by loosening the back.
Slide the opening tool around the edges of the device.
Wedge it open using the plastic opening tool.
To reassemble your device you will need to solder the wires back in position and then follow the other steps in reverse order.
Еще один человек закончил это руководство.
