Введение
This is a guide on how to both replace and/or switch the side of a handle on an Abu Garcia Cardinal S10 fishing reel.
Whether you are looking to replace your old handle with a new one or move the handle from one side to the other this guide will give you a quick and easy rundown of the process.
Выберете то, что вам нужно
To start, you should use a clean towel or cloth to wipe down the reel of any dust and dirt.
Next, loosen the cap of the reel handle by turning it counterclockwise, and once it has become loose enough gently pull the cap out and put it to the side.
Next, firmly grab hold of the handle and pull the handle straight back to remove it from the body of the reel.
Now, you can either bring a new/replacement handle to the reel or switch the handle to the opposite side of the reel body.
Then, gently insert the handle back in until it is fully in the body of the reel.
Now grab the handle cap insert it back into the reel on the opposite side of the handle, and turn it clockwise until it is firmly locked in.
Lastly, crank the handle several times to ensure that it is moving and turning smoothly.
This guide was done on a spinning reel that started with the handle on the default left side and works going from either left to right or right to left. Remember, you will be grateful for taking proper care of your fishing reel the next time you hook a big one.
