Введение
The Nokia 3100b may not vibrate anymore when the phone is set in Vibrate mode. This guide will show you how to access the vibrating unit.
Выберете то, что вам нужно
Press the button on the back of the phone and slide the back panel off.
Remove the battery by pulling it from the phone.
Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
Separate the front cover from the base of the phone.
Set the front cover, as indicated, aside.
Remove the screws indicated using a T6 Torx screwdriver.
Remove them in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple).
Separate the screen assembly from the base of the phone.
Set the screen assembly, as indicated, aside.
The vibrating unit is held in place by friction. Access the bottom of the unit and push upward to release it from the base.
Еще один человек закончил это руководство.
