Выберете то, что вам нужно
Turn the monitor facedown.
Unscrew the 5 screws holding the back cover on.
Take the edge tool or a metal ruler and insert it into the bezel.
Apply pressure and push down.
Do the same to the right side.
Once side of bezel facing you is decoupled, take the back cover and pry it loose.
Remove the Power Button Circuit board Flat Flex Cable from the Power Supply board under the metal cage.
Pull the cord back and out of the way.
