Acer Aspire 3000 Keyboard Replacement
Выберете то, что вам нужно
  1. Acer Aspire 3000 Keyboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 Keyboard Replacement: шаг 2, изображение 1 из 2 Acer Aspire 3000 Keyboard Replacement: шаг 2, изображение 2 из 2
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 Keyboard Replacement: шаг 3, изображение 1 из 2 Acer Aspire 3000 Keyboard Replacement: шаг 3, изображение 2 из 2
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 Keyboard Replacement, Keyboard: шаг 4, изображение 1 из 1
    • Lift the laptop to be on its edge, with the bottom of the screen in the air.
  5. Acer Aspire 3000 Keyboard Replacement: шаг 5, изображение 1 из 1
    • Remove the three 4.6 mm Phillips #1 screws that are on this edge.
  6. Acer Aspire 3000 Keyboard Replacement: шаг 6, изображение 1 из 2 Acer Aspire 3000 Keyboard Replacement: шаг 6, изображение 2 из 2
    • Wedge a spudger into the latch on the right side.
    • Open the lid completely to facilitate removal.
    • Pull the handle of the spudger towards you to pop the first of the tabs that hold this piece in place.
    • Starting from right to left, pop the remaining tabs by lifting up on the panel and rotating the panel to the left.
  7. Acer Aspire 3000 Keyboard Replacement: шаг 7, изображение 1 из 1
    • Unscrew the two 4.6 mm Phillips #1 screws.
  8. Acer Aspire 3000 Keyboard Replacement: шаг 8, изображение 1 из 1
    • Gently lift the top edge of the keyboard out of its place.
    • Do not completely remove the keyboard as there is still a ribbon cable connecting it to the device.
  9. Acer Aspire 3000 Keyboard Replacement: шаг 9, изображение 1 из 1
    • Lift the ZIF connector's black retaining flap. Then gently slide the ribbon cable out.
    • Remove the keyboard.
Заключение
Еще один человек закончил это руководство.
Lykia Harper
Участник с: 10/29/16
258 Репутация
Автор 2 руководств
Команда
Baylor, Team 4-2, Williams Fall 2016 Участник Baylor, Team 4-2, Williams Fall 2016
BU-WILLIAMS-F16S4G2
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 10
За всё время: 780
