Acer Aspire 3000 Wireless Card Replacement
Выберете то, что вам нужно
  1. Acer Aspire 3000 Wireless Card Replacement, Battery: шаг 1, изображение 1 из 1
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 Wireless Card Replacement: шаг 2, изображение 1 из 2 Acer Aspire 3000 Wireless Card Replacement: шаг 2, изображение 2 из 2
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 Wireless Card Replacement: шаг 3, изображение 1 из 2 Acer Aspire 3000 Wireless Card Replacement: шаг 3, изображение 2 из 2
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 Wireless Card Replacement, Wireless Card: шаг 4, изображение 1 из 1
    • Remove the two 4.6 mm Phillips #1 screws on the lower edge of the laptop case.
  5. Acer Aspire 3000 Wireless Card Replacement: шаг 5, изображение 1 из 1
    • Pop the three side tabs out of the back case.
  6. Acer Aspire 3000 Wireless Card Replacement: шаг 6, изображение 1 из 1
    • Remove the panel that covers the graphics card.
  7. Acer Aspire 3000 Wireless Card Replacement: шаг 7, изображение 1 из 1
    • Remove the black and white cables attached to the graphics card.
    • Be careful to lift vertically as to not mess up either part of the connectors.
  8. Acer Aspire 3000 Wireless Card Replacement: шаг 8, изображение 1 из 1
    • Push the white flanges on either side of the graphics card out.
    • The card should lift on its own slightly out of the case.
  9. Acer Aspire 3000 Wireless Card Replacement: шаг 9, изображение 1 из 1
    • Remove the card by lifting up and away from the edge that has all of the contacts on it.
Заключение
Lykia Harper
Участник с: 10/29/16
258 Репутация
Автор 2 руководств
Команда
Baylor, Team 4-2, Williams Fall 2016 Участник Baylor, Team 4-2, Williams Fall 2016
BU-WILLIAMS-F16S4G2
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 946
