Введение
This step-by- step process demonstrates how to install remove and install a new wireless card on your Acer Aspire 3000. It is important to follow the steps carefully in order to prevent damage to the cables upon removal. Damage to the cables may cause a bad connection with the replacement wireless card. Use caution to always remove the battery whenever you are repairing parts of your device.
Выберете то, что вам нужно
Begin with the device face down.
Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
Slide the button found below the battery to the left into the unlocked position.
Locate the battery and the tab to the right of it.
Pull the tab to the right while simultaneously pushing the battery away from you.
Remove the two 4.6 mm Phillips #1 screws on the lower edge of the laptop case.
Remove the card by lifting up and away from the edge that has all of the contacts on it.
