Acer Aspire 3003WLCi Internal Fan Replacement
Выберете то, что вам нужно
  1. Acer Aspire 3003WLCi Internal Fan Replacement, Battery: шаг 1, изображение 1 из 1
    • Turn the Acer Aspire 3003WLCi so that the bottom of the laptop is facing up. Orient it so that the battery is on your left.
  2. Acer Aspire 3003WLCi Internal Fan Replacement: шаг 2, изображение 1 из 3 Acer Aspire 3003WLCi Internal Fan Replacement: шаг 2, изображение 2 из 3 Acer Aspire 3003WLCi Internal Fan Replacement: шаг 2, изображение 3 из 3
    • There will be two switches on the back of the laptop: one at the top of the battery, and one at the bottom.
    • Shift the bottom switch into an upward position in order to unlock the battery.
    • To unlock the upper switch, forcefully push the switch up and hold it in this position.
  3. Acer Aspire 3003WLCi Internal Fan Replacement: шаг 3, изображение 1 из 2 Acer Aspire 3003WLCi Internal Fan Replacement: шаг 3, изображение 2 из 2
    • While holding the upper switch in the upward position, remove the battery by pulling it out to the left.
    • You may need to be a bit forceful when pulling the battery to the left if it hasn't been removed before.
    • You have to maintain pulling the upper switch upwards, or the battery will not come out.
  4. Acer Aspire 3003WLCi Internal Fan Replacement, Internal Fan: шаг 4, изображение 1 из 1
    • The panel you will be removing to access the internal fan is located at the bottom of the laptop.
  5. Acer Aspire 3003WLCi Internal Fan Replacement: шаг 5, изображение 1 из 1
    • Using a Phillips #0 screwdriver, unscrew the two 5mm captive screws on the panel.
    • The screws will not come out of the panel. This is intentional by the manufacturer.
  6. Acer Aspire 3003WLCi Internal Fan Replacement: шаг 6, изображение 1 из 1
    • Lift and remove the panel.
    • If you have difficulty removing the panel, use a spudger to pry the panel open.
  7. Acer Aspire 3003WLCi Internal Fan Replacement: шаг 7, изображение 1 из 3 Acer Aspire 3003WLCi Internal Fan Replacement: шаг 7, изображение 2 из 3 Acer Aspire 3003WLCi Internal Fan Replacement: шаг 7, изображение 3 из 3
    • The fan is in the upper right corner of the panel.
    • Using a Phillips #00 screwdriver, remove each of the four 2.5mm screws securing the fan to the laptop.
  8. Acer Aspire 3003WLCi Internal Fan Replacement: шаг 8, изображение 1 из 2 Acer Aspire 3003WLCi Internal Fan Replacement: шаг 8, изображение 2 из 2
    • Disconnect the fan power cable from the motherboard by pulling the cable up and out of the connector.
  9. Acer Aspire 3003WLCi Internal Fan Replacement: шаг 9, изображение 1 из 2 Acer Aspire 3003WLCi Internal Fan Replacement: шаг 9, изображение 2 из 2
    • Remove the fan by pulling it away from its surrounding copper.
    • The fan is secured on the other side of the copper by a piece of tape, so it may help to wiggle the fan multiple times to try and loosen the tape.
Заключение
Tristin Viale
Участник с: 03/25/19
675 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team S2-G2, Bailey Spring 2019 Участник UMass Dartmouth, Team S2-G2, Bailey Spring 2019
UMASSD-BAILEY-S19S2G2
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 167
