Введение
If your device's screen display is distorted, cracked, flickers, or has tiny dots, replacing the screen will probably solve these issues.
Выберете то, что вам нужно
Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
Position the laptop so you have a clear view of the front of the screen.
Remove the two screw covers at the bottom sides of the screen casing using a flat tool.
Remove the two 5.0 mm Phillips screws. They will be directly underneath the screw covers.
Use a flat tool, to pry open along every side of the front casing of the screen.
Remove the front casing.
Remove the four 5.0 mm Phillips screws located next to every corner of the screen.
Gently remove the tape that covers the connector cable, as highlighted in the first picture.
With a flat tool, gently disconnect the connector cable from the damaged screen.
To reassemble your device, carefully follow these instructions in reverse order.
2 участников успешно повторили данное руководство.
