Введение
This guide requires that you follow the Battery, Keyboard, and Hard Drive removal guides before you start this guide.
Выберете то, что вам нужно
Lay the acer upside down
Use your screwdriver to unscrew all 19 two 5mm Phillips screws from the case
After unscrewing all the screws, lift the case upwards and remove it
Go on the side of the computer
Use the plastic opening tool and press it in between the upper case and lover case
When the plastic tool is in between the cases, start going around the computer until both case are officially not connected
Repeat Step 3 for detaching the rest of the tape
Disconnect all wires from the boards
