Введение
This guide shows you how to install a new keyboard for an Acer Aspire 5100 laptop.
Before using this guide, make sure to review the Acer Aspire 5100 Trouble Shooting page.
Be sure to power off your laptop completely and disconnect from any external power source before beginning installation.
Выберете то, что вам нужно
Open and push the screen back all the way until it is horizontal with the rest of the laptop.
Use an opening tool to remove the panel above the keyboard that has the power button on it.
After you have released the tabs, lift up the panel.
Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
Pull the ribbon under the keyboard to detach it from the motherboard.
Remove the keyboard.
7 участников успешно повторили данное руководство.
Один комментарий
this step is missing steo 0 : before you lift the panel, remove 3 screw that hold the panel
