Введение
If your Acer Aspire screen (model 5100) isn’t producing a clear picture and instead outputs distorted images or intermittent/dead pixels, use this guide to replace the monitor.
The monitor transmits visual data to users through thousands of small pixels. A faulty monitor will transmit distorted or unclear images or no images at all.
Before using this guide, inspect the monitor for any debris that may be interfering with screen quality. Typically, any minute pieces of dust can be removed using an ESD-safe brush or small, damp towel. Be sure to completely shut down your laptop on and off at least two times to confirm that the faulty hardware is the monitor itself.
Before beginning, be sure to turn off your laptop completely and disconnect it from any external power source(s) or monitors if possible.
Выберете то, что вам нужно
Open and push the screen back all the way until it is horizontal with the rest of the laptop.
Use an opening tool to remove the panel above the keyboard that has the power button on it.
After you have released the tabs, lift up the panel.
Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
Pull the ribbon under the keyboard to detach it from the motherboard.
Remove the keyboard.
Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
Flip the laptop upside down.
Remove the four screws from the back panel of the laptop.
Lift the panel up and set it aside.
8 участников успешно повторили данное руководство.
