Введение
This guide will help you replace the display assembly on this device. Make sure the battery is removed before beginning.
Выберете то, что вам нужно
Next to the battery is a switch with a lock symbol on it.
Unlock the switch by sliding it to reveal a red unlock symbol.
Pull the other switch completely while the red unlock symbol is still present. The battery pack should pop up a bit.
Remove the battery pack via the indentation at the top of the battery in between the two switches.
Unscrew the 8.6 mm screws on the back panel with a Phillips #0 screwdriver.
Flip the laptop over as shown.
Locate the six tabs keeping the keyboard in place.
Pull on the edge of the keyboard using a spudger or your hands.
As you pull on the keyboard, push the tabs in one by one using small tweezers.
Once you pop it out and its separated, slowly turn it over to reveal its attachment to the connector.
Using tweezers, slide the the tab down. This will release the connector that you can gently pull out of the socket.
Flip the computer gently so that the back is facing you.
Remove all 12 of the 7.6 mm screws on the backside with a Phillips #0 screwdriver.
Remove 4 of the 5.4 mm screws on the backside with a Phillips #00 screwdriver.
Flip the computer back over.
Unscrew the seven 5.6 mm screws located on the top cover using a Phillips #0 screwdriver.
For the Power button cable and touchpad cable, please disconnect the connector using tweezers to pull down the brown tabs.
For the smaller right and left speaker cables, pull out the black tab completely also using tweezers.
Using a plastic spudger or your hands, carefully lift up the corner of the top panel.
Continue to lift the panel until it is removed completely.
Locate the video cable connector keeping the screen connected to the motherboard.
Unscrew the 8.6 mm bottom screws on the both hinges to separate the screen from the rest.
Remove the circle sticker and unscrew the 6.7 mm screws with a Phillips #0 screwdriver.
Using a Phillips #0 screwdriver, remove all six 3.6mm screws on the sides of the screen.
Disconnect the webcam connector by gently pulling on the tabs using your hands or tweezers.
Еще один человек закончил это руководство.
