Введение
This guide will help you replace the RAM on this device. Make sure the battery is removed before beginning. RAM is used to store information for your laptop. If you are having memory issues, use these steps to replace and upgrade your RAM.
Выберете то, что вам нужно
Next to the battery is a switch with a lock symbol on it.
Unlock the switch by sliding it to reveal a red unlock symbol.
Pull the other switch completely while the red unlock symbol is still present. The battery pack should pop up a bit.
Remove the battery pack via the indentation at the top of the battery in between the two switches.
Use a spudger or plastic opening tool to lift the panel up. Then remove the panel entirely with your hands.
Find two metal pieces on either side of the RAM.
Pull the two tabs apart. The RAM will pop up when released.
Gently pull the RAM out
Repeat step 8 & 9 for the second RAM piece if applicable.
