  1. Turn the laptop over.
    • Turn the laptop over.
  2. "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
  3. Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
  4. PC Laptop Batteries
    An easy fix for a big power boost.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  5. Now remove the battery by lifting it out of the laptop by the side closest to the switches.
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
  6. You have successfully removed the battery. Congratulations!
    • You have successfully removed the battery. Congratulations!
  7. Now, locate the two screws that hold the back cover panel onto the laptop.
    • Now, locate the two screws that hold the back cover panel onto the laptop.
  8. Unscrew both of the screws that are holding the back panel in place with the Philips #00 head.
    • Unscrew both of the screws that are holding the back panel in place with the Philips #00 head.
    • The screws are 3/8" in length and have a 1/4" head.
  9. Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there. Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there.
    • Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there.
  10. After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
    • After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
Заключение
4 участников успешно повторили данное руководство.
Nathan Hanson
Участник с: 08.04.2014
516 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 8-11, Regan Spring 2014 Member of Cal Poly, Team 8-11, Regan Spring 2014
CPSU-REGAN-S14S8G11
4 членов
Автор 9 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 4
За 30 дней: 15
За всё время: 2,166
