Acer Aspire 5253 Hard Drive Replacement
Выберете то, что вам нужно
  1. Acer Aspire 5253 Hard Drive Replacement, Battery: шаг 1, изображение 1 из 1
    • Turn the laptop over.
  2. Acer Aspire 5253 Hard Drive Replacement: шаг 2, изображение 1 из 1
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
  3. Acer Aspire 5253 Hard Drive Replacement: шаг 3, изображение 1 из 1
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
  4. Acer Aspire 5253 Hard Drive Replacement: шаг 4, изображение 1 из 1
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
  5. Acer Aspire 5253 Hard Drive Replacement: шаг 5, изображение 1 из 1
    • You have successfully removed the battery. Congratulations!
  6. Acer Aspire 5253 Hard Drive Replacement, Back Cover Panel: шаг 6, изображение 1 из 1
    • Now, locate the two screws that hold the back cover panel onto the laptop.
  7. Acer Aspire 5253 Hard Drive Replacement: шаг 7, изображение 1 из 1
    • Unscrew both of the screws that are holding the back panel in place with the Philips #00 head.
    • The screws are 3/8" in length and have a 1/4" head.
  8. Acer Aspire 5253 Hard Drive Replacement: шаг 8, изображение 1 из 2 Acer Aspire 5253 Hard Drive Replacement: шаг 8, изображение 2 из 2
    • Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there.
  9. Acer Aspire 5253 Hard Drive Replacement: шаг 9, изображение 1 из 1
    • After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
  10. Acer Aspire 5253 Hard Drive Replacement, Hard Drive: шаг 10, изображение 1 из 1
    • Once the cover panel is off, locate the hard drive.
  11. Acer Aspire 5253 Hard Drive Replacement: шаг 11, изображение 1 из 2 Acer Aspire 5253 Hard Drive Replacement: шаг 11, изображение 2 из 2
    • Locate the two screws that are holding the hard drive in place.
  12. Acer Aspire 5253 Hard Drive Replacement: шаг 12, изображение 1 из 1
    • Remove the two screws using a Phillips #00 screw driver.
  13. Acer Aspire 5253 Hard Drive Replacement: шаг 13, изображение 1 из 1
    • Carefully slide the hard drive in the opposite direction of where the screws are located until it dislocates.
  14. Acer Aspire 5253 Hard Drive Replacement: шаг 14, изображение 1 из 1
    • Pull the hard drive out of its compartment.
Заключение
9 участников успешно повторили данное руководство.
Cynthia Barajas
Участник с: 04/08/14
2 195 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 8-11, Regan Spring 2014 Участник Cal Poly, Team 8-11, Regan Spring 2014
CPSU-REGAN-S14S8G11
4 членов
Автор 15 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 15
За всё время: 7,352
