Введение
This guide will show you how to replace the RAM on your Acer Aspire-5517-1127 laptop. If your device cannot run multiple applications at once smoothly, then replacing the RAM may help.
Выберете то, что вам нужно
Orient the device so that it is upside down facing towards you. The ram panel is in the middle of the device.
The screw is at the bottom of the panel.
Using a Phillips screwdriver (PH1), unscrew the screw from the panel.
Pull the panel away from the device as shown.
Using two fingers, push the tabs inward to release the RAM from its casing.
Pull the RAM towards you to remove it.
2 участников успешно повторили данное руководство.
