Введение
Replacing the disc drive is a fairly simple process that can be completed in around 5 minutes. Make sure the device is unplugged and powered off before you begin.
Запчасти
No parts specified.
  1. Unscrew the two .8 centimeter screws on the bottom plate with the PH #0 screwdriver.
    • Unscrew the two .8 centimeter screws on the bottom plate with the PH #0 screwdriver.
  2. Using your fingers, or the blue plastic spudger tool if needed, remove the plate. Then proceed to unscrew the .4 centimeter Phillips screw on the left side.
    • Using your fingers, or the blue plastic spudger tool if needed, remove the plate.
    • Then proceed to unscrew the .4 centimeter Phillips screw on the left side.
  3. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. You can now pull the disk drive out by hand. You can now pull the disk drive out by hand.
    • You can now pull the disk drive out by hand.
  5. If needed, the small plate can be removed by unscrewing the two .4 centimeter Phillips screws. If needed, the small plate can be removed by unscrewing the two .4 centimeter Phillips screws.
    • If needed, the small plate can be removed by unscrewing the two .4 centimeter Phillips screws.
Заключение
Trysten buckley
Участник с: 09.10.2018
337 Репутация
Автор 3 руководств
Команда
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 3
За всё время: 66
