Введение
Replacing the disc drive is a fairly simple process that can be completed in around 5 minutes. Make sure the device is unplugged and powered off before you begin.
Выберете то, что вам нужно
Unscrew the two .8 centimeter screws on the bottom plate with the PH #0 screwdriver.
Using your fingers, or the blue plastic spudger tool if needed, remove the plate.
Then proceed to unscrew the .4 centimeter Phillips screw on the left side.
If needed, the small plate can be removed by unscrewing the two .4 centimeter Phillips screws.
