Выберете то, что вам нужно
Locate where the hard drive is located on the back side of the laptop and unscrew the two .8cm Long screws.
Once you have have removed the back panel cover, find the hard drive’s location.
Find and locate the two screws that are 0.8cm long that are holding the hard drive in place to the back metal plate.
Carefully take a PH #0 screwdriver and remove the two screws.
Once you have unscrewed the two screws, carefully slide the hard drive the opposite direction of the screws that you just removed, slide the drive till it is free.
