Введение
Replacing the RAM is a simple repair that takes 5 minutes. Make sure laptop is off and unplugged.
Выберете то, что вам нужно
Flip laptop over to show the bottom and lay flat.
Use the Phillips #0 screwdriver to remove the the two .8 centimeter screws from back plate.
Push down the marked bracket with an opening tool or plastic spudger.
Move the Ram at a 45 degree angle and pull out of place.
Почти готово!
Заключение
