Выберете то, что вам нужно
Use spudger to gently pry off open middle cover.
Then flip the middle cover over onto the keyboard.
Use tweezers to detach the cable from the volume button board on the middle cover.
These latches must be released in order for the keyboard to be removed.
Using a spudger, pry the keyboard from the PC, gently.
Lift the keyboard and flip it over, so that it rests on its keys.
Using your hands, open the latch holding the wire in place, and remove the keyboard.
Шаг 7 Prepare Acer Aspire 5740-5780 for Disassembly
Careful: steps 7-10 are sourced from a guide that's marked as in-progress.
Turn the laptop off and remove the power cord.
Press in the SD Card or the SD Card Dummy if no SD Card is there. Remove card when it pops out.
Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
Using an opening tool or your hands, slide the hard drive out of its connector.
Retrieve the WLAN antenna wire from underneath the keyboard.
Detach the LCD cable from the main board.
