Введение
Use this guide to remove the WLAN module from your device.
Выберете то, что вам нужно
Шаг 1 Prepare Acer Aspire 5740-5780 for Disassembly
Careful: steps 1-4 are sourced from a guide that's marked as in-progress.
Turn the laptop off and remove the power cord.
Press in the SD Card or the SD Card Dummy if no SD Card is there. Remove card when it pops out.
Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
Using an opening tool or your hands, slide the hard drive out of its connector.
