Введение
The RAM (Random Access Memory) is used to store the memory of programs that are active. The RAM allows for these programs to be accessed quickly and seamlessly. It works as a short term memory, and without it, many programs would not be usable. It is highly suggested that you remove the battery before performing this replacement.
Выберете то, что вам нужно
Slide the locking switch into the unlocked position to ready the battery for removal.
Remove the two 4.1mm Phillips #0 screws securing the RAM cover.
Use a spudger or other similar tool to pry the cover off.
