Acer Aspire 5742 LCD Panel Replacement
Выберете то, что вам нужно
  1. Acer Aspire 5742 LCD Panel Replacement, Battery: шаг 1, изображение 1 из 3 Acer Aspire 5742 LCD Panel Replacement, Battery: шаг 1, изображение 2 из 3 Acer Aspire 5742 LCD Panel Replacement, Battery: шаг 1, изображение 3 из 3
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 LCD Panel Replacement, Screen bezel screws: шаг 2, изображение 1 из 1
    • Open the laptop lid as far as it will go. Using a small craft knife or similar, remove the two black adhesive screw covers on either side of the screen at the bottom, by inserting the tip of the blade under the edge of the cover.
    • Remove the 2 screws now revealed.
  3. Acer Aspire 5742 LCD Panel Replacement, Removing the screen bezel: шаг 3, изображение 1 из 1
    • Separate the bezel around the screen by using a jimmy or similar tool to release the clips holding it in place. Work around both sides and the top. Finally, turn the laptop on its side in order to work along the bottom. You should now be able to lift off the bezel.
  4. Acer Aspire 5742 LCD Panel Replacement, Removing the LCD panel: шаг 4, изображение 1 из 1
    • Remove 2 screws from the bottom of the LCD panel.
    • At the top of the LCD panel, remove the 2 screws furthest from the corners. Support the panel as you remove these screws.
    • Very gently angle the LCD panel forwards and lay it face down.
  5. Acer Aspire 5742 LCD Panel Replacement, Disconnecting the video cable: шаг 5, изображение 1 из 1
    • Gently lift the transparent adhesive film covering the video connector on the back of the LCD panel, and disconnect the connector.
    • You can now completely remove the LCD panel.
Заключение
Philip Le Riche
Участник с: 02/18/14
30 089 Репутация
Автор 47 руководств
Команда
Restart Project Участник Restart Project
Community
18 членов
Автор 509 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 1,384
